Implanting gold coated magnet as it is
okay, so i ordered http://www.gaussboys.com/store/index.php/magnet-shapes/discs/d0301g.html 10pcs of these things, the are coated in 24kt gold and they have diameters of 1.5mm*thick* and 3.0mm*diameter*.. and im implanting one of those by myself but im just curious will the gold coating keep? i have accepted the upcoming risks if the gold coating brokes down... and btw sorry for my poor english;) and does someone else have experience whit magnets whit only the gold coating?
Specifically gold, but please read the wiki, there's a lot of useful information that can help so much. ^^
If the Au fails, the Ni-Cu-Ni will harmfully interact with your body and cause it to reject painfully. x_x This isn't guaranteed, people have had Au alone work.
What is so iffy about it is how fragile the coating is. When you get them, mix up some super salty water and let those magnets soak for a few days. If a magnet reacts at all... It's reacting in salt water. It hasn't even entered the harshness that is the human body and it's bad. D:>
Honestly, if all 10 fail I wouldn't personally be surprised one bit. Be extremely critical, this is going inside your body.
Installing is the second half that causes failure. That's a really thin layer to wear out, and if a tool like a scalpel or tweezers scratches just a tiny patch of it off, it will fail and reject. :s
I also know that a couple people have had trouble with Gaussboys, just look at things. Make sure the magnets are strong and proper. ^^
