Flexible Biocoating?
Greetings,
Cheers,
So I have this implant which is still in the design phase. I'm pushing towards the goal of usable internal electronics which are as invisible as possible. To that effect, the plans right now give an idea of something which WITHOUT any coating is about a 4*3 cm rectangle in area, and about 2-3mm thick, and on top of that, will also be somewhat flexible, being made up of a circuit board laid on polyamide film and a 1s lipo (ever the one for the ambitious projects, me). I have a long way yet, but I think it could be something quite special.
Anyway, my next question is probably obvious. I wish to maintain the ultra-low profile of this design, and also have it go from a circuit board to something that could be shoved into a forearm without the body getting angry with me. In addition, I would really like to see it retain some of its ability to flex. It would also obviously need to be durable enough to safely withstand being inside an active person's forearm. Budget is also a constraint, lending further to my problem of conflicting parameters.
As an aside, I'd also be eager to hear any inputs anyone has on any safety issues regarding to putting something with such surface area inside for long periods bordering on (ideally) indefinite; This would also extend to any thoughts if either inside the middle of the forearm, or the outside of the wrist would be a more risky procedure than the other.
Cheers,
Ryan
Sincerely,
John Doe
http://m.phys.org/news/2010-01-energy-harvesting-rubber-sheets-power-pacemakers.html
http://m.phys.org/news/2014-04-flexible-plastics-mechanical-vibrations-electrical.html
Cheers.
By the way, LiFePO4 batteries are looking Really attractive. They are apparently not prone to the same problems with combustion or expansion. They are also available to buy and hold similar charges to same sized lipos. They also have a very amenable voltage per cell for the microcontroller im using. Now I just need to find one the right physical size, which may be tough.
I'll keep everyone posted.
Cheers
