Questions about Magnet Implant
Hello everyone, I've read this forum for some time but since I've started to want to move forward on getting a magnet implanted in my finger, I figured I would join and ask a few questions.
Firstly, where can I get suitable magnets? TiN seems to be the best coating, but I can only find them from Dangerous Things, who is indefinitely back-ordered. Is there a comparable alternative I can use if I cannot find a TiN coated magnet?
Secondly, where on my finger should the magnet be implanted and how deep from the surface is ideal? (By surface I mean both from both sides of the skin.)
Thirdly, should I consider injection instead? I hear they are generally less sensitive.
Honestly, DT is the only place I know where to have the TiN ones sourced. Paralines are a little more common, and often if you find a mod shop that'll install them, they'll likely have them in stock and sourced from either Hayworth or Samppa.
Injection is becoming more popular, but I think those work best when you're working with a larger area than the fingertip, IE side of the hand or wrist.
