NFC Ring
So, I just got a ring from Dangerous Things that has two NFC chips in it. It barely doesn't fit me and I was wondering if anyone knew if I could return it for a smaller size or possibly take it to a jeweler and have them make it a little smaller. Thanks in advance!
  • you should probably email @amal - he pops in here occasionally, but email would certainly be better in this case
    I expect a jeweler would be expensive and might damage the NFC
    you can also try asking on the dangerous things forums
  • This is a bit of a quick fix but you can find silicone ring sizers. They just make it fit you a little bit better. I use one just for my highschool class ring.
  • Thanks @Boi and @tekniklr . I’m gonna try the silicone rings, and if those don’t work then I will be sure to email Amal.
  • edited July 20
    For the right size https://goo.gl/images/Uemrp1
    It it a size chart
