Would this work?
Has anyone tried creating an single implant which can triangulate the position of a magnetic field?
I'm thinking something like this.
The extra mass and volume would definitely reduce the overall sensation but hopefully would give a better perception of direction and distance. Still the density of Nd2Fe14B is about 5 times that of Sugru so I don't see that being too much of a problem, the extra cross-sectional area though will mean the vibrations will be spread over a about 4 times the normal area. I could reduce this by adding bumps over the top of each magnet. I could also reduce the shape to a 3 point boomerang shape but I suspect that this would weaken the it too much.
I've also never worked with Sugru before so don't know whether this would be strong enough, probably need a plastic support in the middle to prevent them pulling together.
I'd be interested to know whether people think this will work or if anyone has had any success with a similar design.
