Need to increase testosterone to hopefully get rid of COPD - how to go about it?
How can i increase testosterone from 50ish qmol/l to normal levels?
And what other hormones should i check & increase to fight COPD?
TLDR
My testosterone probably fell due to (a downward spiral of) chronic stress, heavy COPD and inhaled corticosteroids.
Normal T levels should help fix my inflammations AFAIK
Long version
I am a 30-nothing male, with abysmal testosterone level.
3-ish years ago it was probably relatively normal as i had no problems with anything. But then shit started falling down, and my health followed 1 year after.
The reason i noticed low T is because i have a bad COPD (started two years ago) and i noticed it fluctuates on weekly and 4-weekly periods. After ruling out most other options i took a salivary testosterone test (blood test not available to me currently) and it turned out i have 1/9th of the testosterone i should have at my age.
No wonder that my inflammation won't go away, that my bones and back hurt, that i feel beyond old - ancient...
As a kid i had a lot of lung problems but puberty put an end to that and i was impenetrable for 6-8 years. So i assume changing my hormone levels would do the trick again. Also i found some (not really great) studies saying HGH + T help COPD.
Unfortunately doctors here are useless (third world country-like), basically i'm left for dead with COPD and everything else. So asking Dr.'s for TRT or COPD treatment is not an option, i need to fix it on my own.
So what should i take to return my testosterone to normal (of course i would like to keep my fertility - assuming i have any) and what else to help with my COPD?
Any input is greatly appreciated as my life's been on hold for the past 2 years and my bones and joints are starting to degrade :(
Yeah google all your foods you eat to check for hidden estrogens.
Also google raising T-levels naturally.
If your in a medically poor country, best solution whole foods protein good fats and carbs as possible and resistance exercise caffeine and creatine monohydrate and cut out any and all plant estrogens they are poison to you.
terramir
PS: Caffeine is also shown to help with asthma and chronic bronchitis.
https://www.fertstert.org/article/S0015-0282(09)00966-2/pdf
> Plant estrogen affecting human testosterone levels is a myth.
Did you look at the tables the placebo groups are on average older than the test groups this seems to me like they would invalidate the meta analysis since older populations tend to have lower t levels
To the OP one more thing avoid plastic bottles, dishes and utensils and microwave in glass endocrine disruptors can leach from some plastics.
Each study in this meta analysis save for one (Kranse et al., 2005) that had a placebo group has the same age cohort between placebo and non-placebo groups. I'm looking at Table 1 in the linked PDF. Even if you want to disregard that one study, there are 31 others that find the same thing- no link between soy protein and testosterone levels.
@Ancient I don't know where you live but there are websites you can by testosterone in capsule or liquid form. Taking in account your level is 1/9 on normal it should be possible to just go to the doctor and have prescribed the testosterone to you officially, especially after a proper blood test. BTW in case of blood test ask for a full analysis, hormones' are all connected to each other, something else might be lower than normal.
You should still be able to get TRT prescribed by a doctor either via weekly/bi-weekly injection or daily topical gel, though. This is very common; I do weekly subq testosterone injections myself.
