Payment Implant (Purewrist flex conversion)
Hey all,
I located a prepaid card issuer in the US called Purewrist. Their terms are not ideal, but there's really nothing else in the US so I decided to give it a try. It turned out that Amal had an appropriate antenna available so we converted it into the flex form factor, and I had it installed yesterday.
It works really well, and I'm currently running in vivo testing with a variety of reader topologies. The flex implants may be available as a regular item on the DT store sometime in the future, but for now you can order a "card" from Purewrist and send it to Amal to be converted just like a microcard. Here's me paying with the implant immediately after installation:
Pictures attached
Pictures attached
What about the terms makes it non ideal?
Since I had it installed, I've done extensive testing with at least 8 different types of readers. I've been able to get a reliable read on every one without much difficulty. The only ones that require a bit of trial and error at first are the ones with the antenna behind an LCD screen. Usually the middle of the top of the screen works well.
How did you find that their cards would work as an implant? What was the criteria for it to be implantable?
I'm currently exploring conversion of Coil on Module (CoM) cards, which are much more common, especially in the US. You can see in the second and third attachment the type I'm talking about. If you shine a light through you can see the internal antenna, and most have a little antenna trace visible on the outside (that line at the bottom of the right-middle contact).
I've created some little resonant repeater boards as a proof of concept, and they work pretty well. I'll keep you posted as I improve on the design until it's viable as an implant for any CoM module.
How did it work out? It definitely seems like in order for this to be viable, especially when covered by our meat, it needs to have a stronger signal and evidently, that's something you've been focusing on. Any luck or is it an abandoned project?
I am curious to how it might work. I might have to put the chip in the biopolymer myself
Right now I am using rfid in my phone and it didn't work on one of the grocer's payment module
On a semi-related note, I'll shamelessly shill for myself here. I do RFID antenna design, other types of PCB design, and soon medium-batch board population runs as contract work if anyone is interested in that.
