IR Laser used for distance measurement
So I was looking up potential devices that would output accurate information. I found this.
I don't quite have a magnet yet but am planning on getting one soon, would this device, when properly powered and wired, be sufficient to trigger a magnet implant similar to project bottlenose? The specs are included on the page along with a suggested circuit diagram.
Currently I am looking for an IR temperature gauge that does something similar. Just thought I could shoot this idea out.
What do you want to use this for?
If you want to get started right away check out these blog posts about a vibrating distance sensor or the corresponding Instructable. They don't require a magnet implant.
The glasses worn in my Avatar are the first build of the temperature sensing rig.
Since you asked, there is also an IR temperature sensing rig which can output to a vibrating motor or a magnet implant.
Hope this points you in the right direction and welcome to BioHack.
Opting for affordable devices like this seems like a good idea.
I prefer infrared to sonic in concept which is why I was looking into the IR tech.
