Magnet tuner implant for singers, and the problems....
Okay so I was playing with magnets and I had two of them stuck to my little finger, one on my nail and one on my pad. I was able to feel my guitar strings vibrate, microwaves, other magnets yada yada.... That got me thinking if I couldn't use a wave spring and two magnets to create a passive implanted tunner into the neck along my larex. The problems at the moment are:
-I can't put a tourniquet on my neck and live, so controlling bleeding is my main concern. I have no clue as to how I may do this but I am thinking that I may see a plastic surgeon. Please tell me anyone has any better ideas.
-The design I have is simple in theory, two attracting magnets a wave spring about 3/8 in long under pressure. The problem lies in the fact that the whole thing moves like a lot. I have thought about useing silicone (see bullet point three) do to the lower stress it will be under.(compared to a finger)
-Coatings are not normally made to flex like this I am worried TIN will flake off, this coating will need to be as flexible as possible. Maybe a bio glass tube sealed with silicon on the ends to make a dumbbell like shape.
All thoughts and suggestions are appreciated, particularly on controlling bleeding.
Sincerely,
John Doe
Sincerely,
John Doe
What would be the advantage to sensing magnetic fields through your neck? I know you're trying to get a built-in-tuner but are you trying to vibrate your vocal chords at the same rate as a guitar string?
I understand that. We sound differently in our head because we're piloting the vehicle making sound. We usually sound higher pitched when we listen to recordings of ourselves because we can hear vibrations coming through our bodies. You probably know this but I'm putting my thoughts down so people know where I'm coming from. Similarly I heard that throat mics or bone conduction mics can show people what we sound like in our heads.
I don't know that sensing vibrations from your larynx is going to give you a heightened sense of tone recognition but I would love to be wrong. tDCS has been shown to improve tone recognition but you probably knew that too.
I guess the easiest way to test would be to attach a throat mic to an amplifier and run some tiny transducers to your neck.
Your passive system seems like it might be trying to violate thermodynamics or I'm misunderstanding. How would driving a buzzer from piezo elements create usable vibrations?
LINK:
http://makezine.com/projects/make-38-cameras-and-av/piezo-contact-mic/
I like you throat mic Idea though.
You made good points but here is my problem I have been singing scales with my vocal coach for 4 months and have got no ware. Hence why I am going to such extreme measures, the spring was to prevent them from ever coming together and causing trauma.simler to what you have suggested. I thought about a magnetic tunning fork but wouldn't that only be one note?
I don't know what people have developed for feeding a signal to the finger though. Does anyone know what they use for the bottle nose?
This post has a few clear pictures of it. [LINK]
Would it help singing if you knew when you were right on a note? For example, if you holding a note that was exactly middle C it would light up or vibrate. It would also vibrate at C# and B.
Would it be more helpful if it was only in a pre-programmed octave which the singer would decide?
Would it be more helpful if it only responded to whole notes?
Music is not my forte so I appreciate any input, especially if it is phrased like you're speaking to a grade 2 music student.
Sincerely,
John Doe
I know you won't give up music but experimenting with homebrew surgery near a nerve cluster seems unwise to me.
If you can find a digital tuner with LEDs try hooking a vibrator to the LED output and see what happens. Worst case is that you break a cheap tuner and a pager vibrator.
